Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 10-27-2007, 10:39 PM   #1
Jerry Mayfield
Jerry Mayfield Normal reputation
Exclamation 98 Blazer Total Electrical Failure
My daughter's Blazer quit running on her. It appears to be a total electrical failure. I checked the battery and it is ok. None of the lights will come on and when the key is turned on nothing happens, not codes, no lights, absolutely nothing. I checked all of the fuses in the fuse box and they are oK. My thought is that maybe there is a fusable link causing this, but I don't know where to look. I would appreciate any help!
Jerry Mayfield is offline   Reply With Quote
Old 10-27-2007, 11:24 PM   #2
82Stang
82Stang Normal reputation
Re: 98 Blazer Total Electrical Failure
No anything can be an ignition module.
82Stang is offline   Reply With Quote
Old 10-27-2007, 11:27 PM   #3
Jerry Mayfield
No, like I said, there is not indication of any power. It is as if the battery had been removed. Without at least some power, they will not be able to read any codes. I am stumped!
Old 10-28-2007, 09:08 AM   #4
82Stang
Sorry, mixed your question with others I was answering.
No power: I'd check
-battery terminals/cables all the way down to the starter/ground(a ground may be loose or disconnected)(follow wires and make sure they are tight and intact)
-all fuses/relays underhood in power distribution box
try that and respond back
Old 10-28-2007, 11:02 AM   #5
pags20
pags20 Normal reputation
Jerry, sounds as if you have the same problam I have.If you figure it out please let me know and I will do same. thanks pags20
pags20 is offline   Reply With Quote
Old 10-28-2007, 01:14 PM   #6
blazes9395
Newbie mod
blazes9395's Avatar
blazes9395 Normal reputation
You need to get a voltmeter and check for voltage at the battery itself, at the under hood fuse box, the battery cables and see what you get. You could have a bad battery, bad battery cables, it could be a ignition swtich, it could be a few things. Get a voltmeter and do some probing and see whats there.
blazes9395 is offline   Reply With Quote
Bookmarks
Google
Web AF
