Please Helpdksram 10-27-2007, 11:04 PM I am looking for some instructions with photos or anything of how to replace the A/C compressor on a 1990 Buick Regal GS 3.8 V-6.Anything would be helpful. When I look under the car I can not see the compressor.From the top I can see where the belt runs. maxwedge 10-28-2007, 11:34 AM Look under the front of the engine you will need to work from the bottom, try autozone.com, repair guides for gen'l info. dksram 10-29-2007, 02:05 AM Even worse from there.I can't see nothing but the bottom of the radiator.As if the frame is blocking everything.Even after removing the plastic guards. richtazz 10-29-2007, 10:36 AM you're going to have to remove the radiator cooling fans to get at the compressor on that car, it's jammed in there in a nasty spot (bottom front). Automotive Network, Inc., Copyright ©2012
