i could use all the help i can get on my 95 monte carlo V6 3.1marty carlo 10-27-2007, 12:01 AM ok i got this car a month ago when i first got it i had a bucking problem like at 25mph it would surge so i changer the Coil packs,TBS, plugs, air filter, plug wires, and a whole lotta time so i have that problem. and i have a clicking noise coming from the bottem when i give it gas it gos away so i have no clue i was thinking it was the T converter or my fly wheel a guy at a tranny shop said it was the locker witch maybe it is my car has low trac and it will burn the tires out so yeah. ok and i just found a leak in my cooling system right on the back right rear of the engine looks to be right above my excust but it is coming from the engine its a stream probally about alittle bit smaller than a pen. any help would be greatly appreciated thanks marty carlo 10-27-2007, 01:37 PM ok so i dont know if that water leak is from the engine or a hose but i coulndnt see any hose going around there and i just took my oil cap off and it had the milkshake affect on the bottom of the cap and i seen some around the walls inside. what do you guys think help please someone im stumped maxwedge 10-27-2007, 04:13 PM Get it pressure tested, sounds like the intake manifold is leaking, very common. MONTECARLOLT 03-02-2010, 01:41 PM sounds like one of thefrost plugs might have rusted away,about your bucking when you accellerate,that could be a clooged gas filter. Automotive Network, Inc., Copyright ©2012
