What oil to Use?
m-sanborn
10-23-2007, 06:06 PM
I Have a 1995 Regal GS with a 3800. The first motor blew at 100,560 the day after i got the car. I had a motor from a 95 Lesabre put in that motor had 67,000. The motor is makes noise(bearings? they say lifters) for the first 15-25 seconds when started cold. I had it looked at by a couple of people they say that it is loose tolerances in the motor on some years and is perfectly normal. the motor has about 75,000 miles on it now I have been useing a synthetic blend high milage oil and filter. should i use full synthetic. what do you use? any recommedations or opions? Is that nosie normal? they car runs awsome, plenty of power. I have put 8000 on the new motor.
GTP Dad
10-23-2007, 08:16 PM
Stay with what you are using now. You are not doing anything wrong using the synthetic blend especially if it is the high mileage oil. This will condition the seals and help with some of the noise. Stick with the manufacturers oil weight recommendation. A heavier weight oil may help with the noise but may cause other problems.
m-sanborn
10-26-2007, 07:59 PM
:smokin: I Have a 1995 Regal GS with a 3800. The first motor blew at 100,560 the day after i got the car. I had a motor from a 95 Lesabre put in that motor had 67,000. The motor is makes noise(bearings? they say lifters) for the first 15-25 seconds when started cold. I had it looked at by a couple of people they say that it is loose tolerances in the motor on some years and is perfectly normal. the motor has about 75,000 miles on it now I have been useing a synthetic blend high milage oil and filter. should i use full synthetic. what do you use? any recommedations or opions? Is that nosie normal? they car runs awsome, plenty of power. I have put 8000 on the new motor. Any imput on what oil to use would be great:smokin:
spinne1
10-26-2007, 09:39 PM
I think you should use 10W-30 as Buick suggests. I'd use the cheapest oil you can find. All oils that meet the standards are basically the same. The additives are the only real difference and I doubt they make a huge difference.
As for synthetic, I believe it is in fact better, but how much better is the question, especially considering the huge increase in costs. Now that your car has significant wear, it may not be worth it to now switch to synthetic, as this article suggests:
http://searchwarp.com/swa7388.htm
HotZ28
10-26-2007, 10:31 PM
BE COURTEOUS: AVOID DUPLICATE POSTS
Do not post the same discussion more than once on a discussion forum or on many forums. Duplicate discussions can be frustrating for other members, especially for those whose time and energy is limited. Weeding through the same discussion in multiple locations can be not only frustrating, but down right annoying. Duplicate discussions will be deleted. Reposting the same message repeatedly can be interpreted as SPAM and could result in the loss of your membership. Also be conscious of your fellow members and avoid making meaningless posts for the sole purpose of increasing your post count. Please Read: Af Community Guidlines (http://www.automotiveforums.com/vbulletin/guidelines.html)
