10-25-2007, 03:59 PM
94 Lesabre.. Tried Many Things..nothing is working
OK... this is so irritating ive changed my ignition module my fuel pressure relay.. changed my O2 sensor and the car still jumps and shuts off..
when i was accerelatiing the car... the rpm wont go past 4 it goes down.. will not go past 4.. can that be a problem..
last thing i might assume it is.. FUEL PUMP??..
someone please help me.. i need my 94 running
i changed the PCM and same thing happened..
and my car only has 51k original miles
10-25-2007, 04:15 PM
Re: 94 Lesabre.. Tried Many Things..nothing is working
For the money you spent replacing good parts, you could have taken it to a good mechanic and got a proper diagnosis, which is exactly what I suggest you do now.
10-25-2007, 06:12 PM
What do you mean by the car jumps and shuts off?
Does it jump and shut off when you put it in gear?
As for it not revving past 4? do you mean 4,000 RPMS, it might not rev that high if that is where the governor is set to, which won't cause any driveability probelms.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
10-25-2007, 06:49 PM
haha.. i aint wasted no money on parts.. i get them for free from my brother at auto zone..
the car shuts off no matter if its in Park or in Reverse Or In Drive.. it shuts off.. the rpm jumps up and down when its on park and it wanna shut off.. but then the service engine soon light comes on and the car stays on with the SES light.. pretty weird...
10-26-2007, 09:31 AM
Does your brother own an Auto Zone? How did he get them?
10-26-2007, 04:08 PM
5 parts...5 fingers. lol
10-26-2007, 04:19 PM
AF Moderator Elite
The problem could be, FREE AUTO ZONE PARTS!
Knowledge can be communicated, but not wisdom! “Ye shall know the truth and the truth shall set you free."
10-26-2007, 05:04 PM
I can't imagine you are driving in reverse at 4000 RPM's!So when you say it jumps and shuts off in Park,Reverse or Drive do you mean just your tach or is the engine RPM actually jumping around? It sounds like an electrical igmition problem to me, if it's missing at high RPM's.
BTW, I'm with you regarding not taking it in to a shop, especially if you can get parts easily. The reason we are on this forum in the first place is to try and fix cars ourselves.
10-26-2007, 09:26 PM
Yes, but he has started FIVE posts about this car and its problem, none of which has helped him fix it because his problem needs professional diagnosis. He could go get a crank position sensor, ignition module, fuel pump, fuel filter, throttle position sensor, new injectors, new plugs and wires, a new cam magnet, etc. etc. but until he knows what is wrong, he is just throwing parts at it instead of finding out what is wrong. It is great to try not to take a car in, but once all the free advice does not fix your car, asking over and over again about it is not going to fix it.
10-26-2007, 10:50 PM
AF Moderator Elite
Thanks spinne1, I couldn't of said it better myself!
BTW, T_MAK_510, Please Read: Af Community Guidlines especially this part;
BE COURTEOUS: AVOID DUPLICATE POSTS
Do not post the same discussion more than once on a discussion forum or on many forums. Duplicate discussions can be frustrating for other members, especially for those whose time and energy is limited. Weeding through the same discussion in multiple locations can be not only frustrating, but down right annoying. Duplicate discussions will be deleted. Reposting the same message repeatedly can be interpreted as SPAM and could result in the loss of your membership. Also be conscious of your fellow members and avoid making meaningless posts for the sole purpose of increasing your post count.
10-26-2007, 11:42 PM
I agree with jerryls, the whole idea of the forum is to find help because you cannot afford to have it diagnosed and fixed by a mechanic.
and without a MIL it makes it even harder to locate the problem unless it is very obvious, I know I am a mechanic by trade, you could spend alot of money on diagnostics time.
10-27-2007, 09:18 AM
AF Moderator Elite
I think the point spinne1 was trying to make here is; the OP has posted seven (7) threads this month, all similar, or related to the same problem. All of these threads/post should be confined to one thread! I addition, I feel confident that a good “mechanic by trade” would use proper diagnostic techniques to find the solution and not suggest throwing parts at the symptoms. Feel free to participate in any one, or all seven, listed below.
http://www.automotiveforums.com/vbul...d.php?t=761425
http://www.automotiveforums.com/vbul...d.php?t=761094
http://www.automotiveforums.com/vbul...d.php?t=759995
http://www.automotiveforums.com/vbul...d.php?t=756700
http://www.automotiveforums.com/vbul...d.php?t=759948
http://www.automotiveforums.com/vbul...d.php?t=759950
http://www.automotiveforums.com/vbul...d.php?t=756499
10-28-2007, 10:15 AM
Well all those thread were a bit excessive, I agree.
but I never suggested throwing parts at it, I was just agreeing with jerry about the whole idea of this forum.
10-28-2007, 10:30 AM
Well we know he cannot get it scanned for codes because the OBDII scanner or any diagnostic machine will not connect, this is probably due to a power short at the connector. Does anyone have the pin outs for the OBDII (16pin) or data link (GM-1 12 pin) connector on his vehicle, so he can trace the the power problem and get the codes checked?
10-28-2007, 02:03 PM
Registered Offender
'94 LeSabre is probably a 16-pin DLC. I'd wager a small beverage on that one.
Regardless, a proper scanner will access it, either a Tech (Vetronix) or MT2500 (SnapOn), and with the appropriate adapters should communicate BOTH WAYS. If there is no 12VDC power at the 16-pin DLC (Pin 16), check fuses. The 12-pin DLC uses external power, so it is a non-issue.
After having spent so much time on parts replacing, a diagnosis is going to be the best and fastest solution. Your brother at Ought-Tow-Zone is not likely going to be able to help, since I have seen none of them with the appropriate scanner to communicate with your vehicle. They don't even offer one for sale, so they likely don't have one to use.
