ECU question
jdm_power
10-24-2007, 09:17 PM
i have h22a and i just put a ls vtec ecu (h22 ecu doesnt work, dont buy from osaka) is it bad to drive the car with the ls vtec ecu ? is vtec supose to kick with the wrong ecu ?
VictorPerez
10-25-2007, 04:07 AM
yes doesnt matter what ECU u use as long as its a VTEC but with out the right one it will run like crap
Greenblurr93
10-25-2007, 08:07 AM
it does matter.... the fuel maps will be WAY off and the timing maps as well... your risking melting a piston if you run that ecu.... not to mention i think the H22 had secondary butterflies and the ECU youre using (Im assuming its either a P28 or P72) might not have the board built in for it, so they wont work. (Unless its a P72, then they'll work)
CivicSpoon
10-25-2007, 12:02 PM
H22A peak & hold injectors on a saturated compatible ecu :thumbsdow
Greenblurr93
10-25-2007, 12:30 PM
Ah.. i knew i was missing something... basically NO ITS NOT OK to use that ecu with your motor
jdm_power
10-25-2007, 03:30 PM
so its not ok to run my car with that ecu ? we just replaced the vtec pressure sensor and the car runs good, vtec kicks, but u guys are saying its not good to run it with that ecu? , even for a couple of dayz till i switch it to p13 ecu?
Greenblurr93
10-25-2007, 03:34 PM
you can do some serious damage without even knowing it..... so use it at your own risk
