NP249 VC recharged or new?jaz1314 10-23-2007, 06:35 PM So I am in the process of getting my VC replaced, had the locking wheels after hot causing the crow hop into parking spots. Tossed around the idea of buying a recharged unit from some company in CA. Apparently they can drain and refill the silicone fluid that goes bad but nothing else is touched, to my understanding. At 200.00 per unit it sounded like a good way to go, hwoever after reading an article on Rockland Standard Gear on the NP249 and finding out that the seals inside the VC go bad I decided to spend an extra 130 to get a new, updated version of the NP249 coupler. I do not want to be doing this again next year. Alos note that a bad VC will put a major pounding on the front diff and can cause it top fail. If you got wheel hop on tight turns, fix the VC before it costs you even more. Jaz1314 94 JGC Laredo nickname "Frankenstein":smokin: http://www.automotiveforums.com/vbulletin/images/statusicon/user_online.gif Automotive Network, Inc., Copyright ©2012
