rear stop light
Google
Web AF
agucba
10-23-2007, 03:14 PM
i need to replace my rear stop light, but Im not too sure how I need to proceed. I tried pulling the plastic cover from outside and seems to be really tight, should I use more mustle or what should I do? thanks
typesix
10-23-2007, 04:03 PM
Replacing stop light is done inside the trunk area. Remove cover in trunk where light is located, it should pop off. Bulb socket should twist out.
RIP
10-23-2007, 05:04 PM
All Camrys are not created equal. Which year?
agucba
10-23-2007, 05:52 PM
its a 99 camry, when I pulled the cover from inside the trunk, i do see the back part of the lights. So I believe then I need to pull harder then. Thank you
JH32552
10-31-2007, 10:05 AM
I just took apart my 3rd brake light in my 94 Camry to clean it. All I had to do was grab the plastic cover from the rear shelf (in the car) and snap it off. Then, I removed 2 screws and the whole unit was dismantled and able to be cleaned.
Google
Web AF
