Re: Head gasket questions
I agree with inafogg, except it is in fact an interference engine. You could also use those big paper/binder clips things (the black plastic, with thin metal tabs that you squeeze), and secure the belt to the lower cover. That way it should keep enough tension on the belt to keep it from slipping off the crank pulley. But as long as you disconnect everything from the intake manifold, there's no reason to remove it from the head. There's no reason to have to remove the exhaust manifold either, as long as you disconnect it from the rest of the pipe. I have a Chilton's manual (Haynes and Chilton's are made by the same company so they're basically the same), and it has a pretty big list of stuff the take off, but most of it is just plugs that need to be disconnected. It also doesn't say you have to remove the manifolds, it does say to remove their brackets though; since they are connected to the manifolds as well as the short block.
