96 Sebring Conv hard start, rough idlemkal2 10-22-2007, 04:12 PM 1996 Sebring Converable, 2.5l, 98K miles. Having a hard start (cold engine), about 2-5 sec cranking (used to start within 1-2 sec of cranking), once started a rough idle. The idle gets better after the engine warms up. No ignition miss, or fault codes. Plugs and wires, cap were replaced in June'07 approx 93K miles. bearcatdon 11-04-2007, 06:37 PM Sounds like your IAC valve may need cleaning. mkal2 11-10-2007, 01:59 PM I did have the intake plenum off to replace the wires and plugs. This symptom (hard start, poor idle) started about 1 week afterwards. As of today, it started within 2-3 sec, idle is acceptable, considering 98K miles. Recently added about 10 gal of fuel. I re-checked that all the vacuum and electrical connections were on and tight. Would putting a bottle of fuel injector cleaner cause a hard start condidtion (prior to putting in fresh fuel)? bearcatdon 11-10-2007, 08:08 PM Fuel injector cleaner shouldn't cause an issue. You can also spray some throttle body cleaner down it's throat. Automotive Network, Inc., Copyright ©2012
