Re: 95 sonoma wiring prob
when does this problem happen, is it when you are driving or at idle, or is it with the engine off?
it sounds like your problem might be a bad ground from the battery. did you check your connections on your battery terminals for corrosion? if it happens when the truck is off, that might be your problem. also check connections on your alternator, since that is what powers your accessories when the engine is running.
as for the grounds, i think the devices like locks and windows ground on the door or the chassis nearest the device. the ground for the ABS and brakes is in a different location and not the same wire, so thats why its probably the connection on your battery or alternator, or a bad connection with the negative battery cable and the chassis. trace the negative battery cable and you should find a couple places where it connects to the chassis and engine, those grounds are probably corroded.
- Brian
91 Dodge Shadow 2.5 convertible
96 Chevy S10 2.2 5-speed
94 GMC Sonoma 4.3 V6 (current)
