2.2 l engine mount torque specs
pfofit
10-19-2007, 02:54 PM
Have tried searching but can seem to find the info i need.
Have changed the engine mount block insert and I am looking for the torque specs for the associated bolts.
15 mm Frame nuts:
Internal 13mm bolts holding the engine brace:
Brace to engine 15 mm bolts:
The 3, 15mm nuts on cover plate:
Anybody have them and willing to share. :wink:
Thanks
dpannazzo
10-19-2007, 10:46 PM
Don't know if this helps.
It is not as detailed in which bolts it specifies as you are.
Found it on the ALLDATA website.
If it does, can you help me with my post regarding vacuum lines on a 995 & 98 2.2 engine.
Engine Lift Bracket Nut 50 Nm (37 ft. lbs.)
Engine Mount Strut Bolt 100 + 90°Nm (74 + 90°ft. lbs.)
Engine Mount Strut Bracket Bolt (Rear) 75 Nm (55 ft. lbs.)
Engine Mount Strut Bracket Bolt (Front) 66 Nm (49 ft. lbs.)
Engine Mount Assembly Cage Nuts 45 Nm (33 ft. lbs.)
Engine Mount Assembly To Body Nuts 66 Nm (49 ft. lbs.)
Engine Mount Assembly To Accessory Bracket Bolts 60 + 90°Nm (44 + 90°ft. lbs.)
pfofit
10-20-2007, 11:56 AM
That's great, thanks. Everything except the smaller internal 13mils, I'll set them up to around 40.
I posted some comments in your vaccumm query, hope they help.
Thanking you very much.
cheers
