Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Corsica
Old 10-18-2007, 10:41 PM   #1
aydensmommy0712
aydensmommy0712 Normal reputation
what should i do about a blown head gasket?
ok i thought about getting my friends 94 corsica but it has a blown head gasket and i guess she said its overheated a couple of times on her already...my bf said i should go ahead and replace the whole engine im just wondering what u guys on here think? should i pull the engine out or no? and just replace the head gasket
Ayden's Mommy
aydensmommy0712 is offline   Reply With Quote
Old 10-18-2007, 10:55 PM   #2
aydensmommy0712
Re: what should i do about a blown head gasket?
any suggestions will help me since i kno nothing about cars
Ayden's Mommy
Old 10-29-2007, 07:12 PM   #3
loosenut74
loosenut74 Normal reputation
remill the head, new head bolts and you should be fine...
loosenut74 is offline   Reply With Quote
Old 10-29-2007, 09:24 PM   #4
jsgold
jsgold Normal reputation
I would be wary of a car if they continued to drive it with a blown head gasket. If they parked it right away you should remove the head, take it to a machine shop for checking (for cracks) get it milled as suggested, and a valve job. This is normally what they all do as standard head servicing. Should run about 100 bucks plus or minus unless you have a cracked head. Most shops can repair cracks(which are COMMON on GM's) but you could wind up replacing with a rebuilt head for 200-300 bucks. Then replace gaskets, head bolts. You did not mention if this is a 4 cylinder or a 6. If it a 6 cylinder you might consider both heads getting checked.... I have been through this twice and both times the head was cracked, so a good machine shop is a MUST.
I used to be indecisive, now I am not so sure.
jsgold is offline   Reply With Quote
Old 10-31-2007, 09:14 PM   #5
loosenut74
It"s a four cyl, this person lives in huber heights, not far from me?.... but the info you provided was valid, especally this part "I would be wary of a car if they continued to drive it with a blown head gasket. " and this part "Then replace gasket(s), and head bolts."
Old 11-17-2007, 07:51 PM   #6
rhandwor
rhandwor Normal reputation
You always take a chance on this type of vehicle. If you do your own work and have a good machine shop you should be ok. Another problem is if a lot of anti freeze got into the motor the bearings can be shot. I would recommend a rebuilt long block but it would be cheaper to buy another good used car if you pay for repairs.
If you can afford it buy another good used car.
rhandwor is offline   Reply With Quote
Bookmarks
Google
Web AF
