hi. problem with 96 s10adanrdz 10-18-2007, 08:35 PM when my ac is on the reserve for antifreeze gets hot when idle.. but when runnin gauge goes back to normal.. when i turn it off it bubbles at reserve.. anyone please help me here... emt1134 10-18-2007, 08:59 PM what does your temperature gauge read when this happens ? Your problem may be related to a faulty radiator cap, which isn't keeping enough pressure on the cooling system to raise the boiling point. blazes9395 10-18-2007, 09:39 PM How hi does your guage get? It is normal for it to warm up a little, but not too much. The engine has load on it when the compressor is working, plus the transfer of heat from the condensor warms things up a little. This does put more load on the cooling system, so if your cooling system is not working effeciently then you could have problems. As mentioned by emit1134, it could be something as simple as a bad rad cap. It could be a cooling fan clutch which isn't working properly. When was the last time you had the cooling system flushed? old_master 10-18-2007, 09:51 PM Could be any one or more of several things: faulty fan clutch, faulty radiator cap, restricted tubes in the radiator, insufficient air flow through the radiator, faulty thermostat, serpentine belt slipping, or a faulty water pump. Bottom line is insufficient cooling, and any one of these things can cause it. ericn1300 10-18-2007, 11:42 PM start by replacing the thermo and the radiator cap. under $15 even if you splurge on the good stuff. If that doesn't fix it, get a pressure check done on the cooling system. Automotive Network, Inc., Copyright ©2012
