My unsolvable mystery! - Gas smell/ low mpg
Google
Web AF
mmuah
10-18-2007, 01:41 AM
My car is horrible on gas - about 20mpg (really bad for a civic coupe)
Besides that I've been smelling a really strong gas smell everytime I start up - it'll last for about 5- 10 mins... what is this?
I have already changed:
air filter
spark plugs/wires
distributor (it was leaking oil)
o2 sensor
In case it helps:
I also get this horrible pinging noise.. and I don't use cheap gas..
My check engine light used to go on, hasn't since I changed my o2 sensor, however, before i did - i ran a diagnostic and got: fuel too lean/ rich
Pls help... I have to inspect it next month.. and I know it won't pass in its current condition
kristy
95 civic ex coupe 1.6 ltr vtec
Also,
I'd also like to make sure my distributor timing is on point.. anyone have any pics / tips..
would I be able to do the work myself?
Greenblurr93
10-18-2007, 09:01 AM
make sure the spark plugs are gapped correctly, (what brand are they? anything other than denso or NGK is junk in a honda) change your fuel filter. also make sure the evap system is working
EZFrank
10-19-2007, 03:26 AM
check timing or timing belt
mid_night_blueS13
10-19-2007, 03:44 PM
to me sounds like your timing is out
Christ
10-22-2007, 01:06 AM
Fact: If you're smelling gas from under the hood, or anywhere other than the intake/exhaust directly, you're probably leaking it.
Fact: If you're dumping THAT much raw fuel, some of it is going into your oil... meaning that your bearings are probably getting wiped, which might account for the "horrible pinging noise"
Fact: Higher octane fuel (when you don't actually NEED it...) does NOT promote better fuel mileage or more power.. it's actually a waste of money, as are most fuel additives that claim Octane increases... when it says 5 points increase, it MEANS .5... so if you're purchasing 87 normally, and you add octane booster, you're only up to 87.5.. which WON'T stop spark knocking or compression knock.
Myth: Well, there really isn't one here, but I had to include it anyway, since it's a Fact/Myth post.
Google
Web AF
