Seat beltsmike561 10-17-2007, 12:09 AM Both front seatbelts dont lock, i know some cars if you tug on the belt hard they will lock, and some only lock when in an accident or braking. are mine supposed to lock when they are tugged on or when the brake is pressed or in a collision? i would think its not the last two, my car doesnt seem to be that advanced. GreyGoose006 10-17-2007, 12:40 AM idk but mine never lock either. however, i can get them to lock loose by doing a sort of double pull. mine seem to work like window shades. pull out and snap and it stays in its position. pull again and it retracts mike561 10-17-2007, 12:49 AM yeah if i pull mine out or lean forward with it on it will stay out, then i have to give it a little tug to retract, but it still never locks. i dont recall if anyone on here knows much about seatbelts either silicon212 10-17-2007, 01:38 AM These cars are equipped with inertial type belt retractors. They will not lock unless there's rapid deceleration (or high-G cornering). PeteA216 10-17-2007, 12:54 PM These cars are equipped with inertial type belt retractors. They will not lock unless there's rapid deceleration (or high-G cornering). They should lock like Silicon said. If you really want to make sure they do, make a fash, sharp, hard turn enough to even squeal the tires a bit and the belt should lockup. If you're really nuts, go rearend someone and see if they lock. <- Kidding. '97ventureowner 10-17-2007, 02:05 PM They should lock like Silicon said. If you really want to make sure they do, make a fash, sharp, hard turn enough to even squeal the tires a bit and the belt should lockup.. Fash..??? Pete, you really need to lay off those lunchtime beers. :lol: :cheers: mike561 10-17-2007, 02:31 PM lol ok good to know then PeteA216 10-22-2007, 11:36 PM Fash..??? Pete, you really need to lay off those lunchtime beers. Hahaha, wow... that, and probably proofread a little better before posting. PS: And if I was dunrk I'd be tpynig a ltilte mroe lkie tihs. :grinno: mike561 10-23-2007, 12:22 AM I swe eear to d runk im nott god! GreyGoose006 10-23-2007, 10:01 AM or just give them a good tug when you are sitting still... safer. mike561 11-06-2007, 07:26 PM my car is probably equipped with the "weighted pendulum" style belts then im geussing... bhw33191 11-13-2007, 08:01 PM Both front seatbelts dont lock, i know some cars if you tug on the belt hard they will lock, and some only lock when in an accident or braking. are mine supposed to lock when they are tugged on or when the brake is pressed or in a collision? i would think its not the last two, my car doesnt seem to be that advanced. My car seems to do the same thing but only on rare occations for some reason. If the seat belt is loose when i unbuckle and doesnt retract, it will retract if i open the door. Is this suppose to happen cuz i dont get the point of that. Why wouldn't it just retract in the first place? I dont know if this has anything to do with it but it just brought that question to mind. mike561 11-13-2007, 08:16 PM mine get stuck too when the door is closed and you pull them out sometimes, when you open the door there is a little black buttion that is released and thats why they wind up easier. also i checked to see if the belt locks at a sudden stop and they do, you have to jam on the brake hard. theres a little weight inside the mechanism that swings forward in a sudden stop to lock the belts. mike561 11-15-2007, 06:55 PM Note illustration http://static.howstuffworks.com/gif/seatbelt-rocker.gif mike561 11-15-2007, 11:46 PM Another question, how safe are the backseat belts being as how they only go over your lap unlike the front ones??? silicon212 11-15-2007, 11:54 PM Well, you won't go flying through the windshield if you're in the back seat, so I'd probably leave my belts off (I wouldn't say the same for kids, though). In a rapid deceleration, you just might get stomach cramps and a face-plant on the front seats. mike561 11-16-2007, 03:03 PM yeah i was wondering why they only made lap belts on these cars in the backseats, i know on some have the complete shoulder belts in the backseats Automotive Network, Inc., Copyright ©2012
