83 Rabbit/gti For Sale65sub 10-15-2007, 10:46 PM THIS CAR IS IN NEAR PERFECT SHAPE. THE INTERIOR IS THE ORGINAL BLUE WITH NO RIPS IN THE SEATS AND ALL PANELS ARE PERFECT. THE CAR HAS NEVER BEEN WRECKED. tHE PAINT SHINES BUT HAS SOME SMALL CHIPS. tHE ENGINE IS A 1.8L BLOCK BORED 40 OVER WITH REVERSE DOME JE PISTONS AND RINGS. THE HEAD HAS BEEN COMPLETLY POCKET PORTED AND HAD A VALVE JOB AND NEW GUIDES. THE VALVES WERE CUT TO MATCH THE HEAD AND SHORTENED TO RUN WITH NO LASH. I HAD A CUSTOM GROUND WEBB RACING CAMS -CAM MADE WITH A 450 TOTAL AND A 110 LOB CENTER FOR GOOD IDLE.ALSO A TECHTONICS ADJUSTABLE CAM SPROCKET. IT ALSO HAS A NEWSPEED THROTTLEBODY AND BRAND NEW K&N AIR FILTER. EXHAUST IS A PACESETTER HEADER STRAIGHT WITH A MUFFLER, NO CAT. iT HAS NUESPEED UPPER AND LOWER SWAY BARS AND THE REAR UPPER SWAY BAR. I HAVE FULL ADJUSTABLE KONIS WITH EIBACH SPRINGS . THE CAR ALSO HAS A SET OF NEW ULTRA-LITE AUTOMETER GAUGES AND SENDERS. THE CLUTCH IS A CENTERFORCE DUAL FRICTION AND IS ALSO NEW.THE ENGINE COMPARTMENT WAS COMPLETLY DISASEMBLED AND CLEANED BEFOR INSTALL. THE CAR ALSO HAS NEW AXLES , NEWER TIRES AND A BRAND NEW WINDSHEILD. THIS IS BASICALLY THE FUNEST STREET CAR YOU WILL EVER OWN! THE ENGINE HAS 500 MILES ON IT AND THE OD SHOWS 141XXX. ALMOST EVERYTHING HAS BEEN REPLACED ON THIS CAR, i JUST HAVE HIT SLOW TIMES AND MUST SELL . ASKING $7500 OBO THANKS Automotive Network, Inc., Copyright ©2012
