Valve clearenceruberpoliceman 10-15-2007, 01:01 PM anybody know the valve clearence for a 86 305?..(Using a feeler gauge)...changed head gaskets and need to reset valves....Thanks. ruberpoliceman 10-15-2007, 03:20 PM All stock silicon212 10-15-2007, 04:53 PM All stock ? The engine has hydraulic lifters - there should be no lash at all. If you're putting the engine together, tighten down the rocker with one hand while spinning the pushrod with the other - once the pushrod encounters resistance to your spinning, turn it one half turn further tight and that's your adjustment. ruberpoliceman 10-15-2007, 05:44 PM Cool, thanks. vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
