Painting my truckPatKGreen 10-15-2007, 12:33 AM Howdy guys- If anyone could help me, I'd be forever grateful. I'm putting on Clearcoat/basecoat urethane -http://www.tcpglobal.com/restorationshop/rsp2919.aspx That kit should be all I need, right? Any tips, suggestions, important things I should be aware of? Please help! TuT 12-13-2007, 02:31 PM Looks like this kit doesn't contain any sealer, which if your colour is similar and your clearcoat is still good on your truck you can do without. Problem comes a year or two down the road. Just don't break through that clear when your scuffing the truck up. Also you should get a wax and grease remover to clean the surface before you scuff and after you scuff. then again after you mask. And a tack rag (not and option). Remove it from the rapper and let it breath for a day before you lightly tack off the car emediatley before base coat. Do you have any body work? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
