need parts 78-up
we are restoring the 85 elky and need parts, including:
A:
pair of upper door hinges with good detent rollers, no slop
hinge pin bushings dont matter, we will replace them regardless,
only want hinges that have no wear completely through the pin bushings though
B:
need exterior pass side front pillar chrome trim that sits between the door roof frame opening and the roof rail weatherstrip panel, the chrome trim i need is sadnwiched inbetween
need one that is not dented or scraped
C:
need the painted steel vertical weatherstrip channel that screws onto the vertical pillar/post between the door glass rear vertical edge and the quarter glass,
D:
also need the black painted exterior trim piece that clips onto the same pillar/post (it clips on with the 3 plastic black flat clips)
need to be non-dented and straight
need dark maroon door panels for power doors, upper and lower ones
need door sill plates pair, good used shape, not damaged
let me know how much to 62656 mailed 2-3 day
and my zip is 62656
i can call you if you PM/email a number so we can be sure of exact parts
need to find all of the above parts ASAP !!!
trying to get the 85 done, need hinges so we can hang the doors and paint the car ASAP
where can i find these ?
thanks for anything!
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
