92 toyota pick up speed sensor problems
bradleyjr22
10-14-2007, 04:32 PM
i have a 1992 toyota pickup 4x4 with a 3.0 v6 and auto transmission. the speedometer does not work i pulled the harness of of the sensor that is on the tail shaft of the transfer case and tested all the wires i had power coming down, the ground was good then i went to test the third wirewitch should be sending pwer up to the speedo well i hooked up my tester and when i grounded the tester the speedo mooved not a fancy tester just a light this is wierd and i cant figure it out and i am tired of the tickets can any one help me
fourwd1
10-15-2007, 08:36 AM
I don't have any experience with the electronic speedo.
Check the Factory Service Manual for trouble shooting instructions.
There is a FSM thread at the top of the main page that links to FSMs.
vin brown
11-27-2007, 01:10 PM
chech the speed sensor gear on the gear box or the cluster unit not sending pulse to ecu,chech harness or speedometer cable
