TRAC lightbuckeye1872 10-13-2007, 11:01 PM Hello, I have 2000 GTP, 30k. When it rains heavy or I take car to get washed the TRAC light comes on. After driving for few miles and I shut it off and fire it back up light is off. Sensor getting wet? Thanks BNaylor 10-14-2007, 01:20 PM The problem is which one? There are four. Common problem is the electrical connector at the hub for the wheel sensor gets loose or water intrusion due to a bad seal. Remove the electrical connectors and check the seal. Also, use electrical contact cleaner to remove any corrosion and water. Automotive Network, Inc., Copyright ©2012
