remote fob program616bret 10-12-2007, 08:23 AM Please reply with instructions on how to program a new remote keyless fob. 2002 Windstar van. Thank you. puumalad 10-12-2007, 11:03 AM I can't help you other than to say I believe those instructions are listed in the owners manual. They were in there for my 2003 Explorer. Dale garync1 10-12-2007, 11:12 AM Remote Keyless Entry Transmitter Reprogramming This May not work on your year>>> NOTE: The reprogramming procedure is basically identical for all vehicles. Exceptions will be identified within each step. Remote Keyless Entry Transmitter Reprogramming 1. Locate the 2-pin RKE programming connector. Refer to RKE Programming Connector Location list below. 2. Turn ignition switch to the RUN position. 3. Using a jumper wire or alligator clip momentarily short the two terminals within the 2-pin program connector. On Econoline models you will need to short these terminals for the duration of the reprogramming procedure. The doors will lock then unlock on all models except Contour and Mystique. On Contour and Mystique models only the horn will sound and the exterior lights will flash. 4. Press any button on the remote keyless entry transmitter. All doors will lock then unlock to verify transmitter has been programmed. The horn will sound and the exterior lights will flash on the Contour and Mystique. NOTE: Programming in the first transmitter will erase all other previously programmed transmitters. All transmitters that are to operate with the vehicle (up to four transmitters) must be programmed during Steps 4 and 5. 5. Repeat Step 4 for any additional remote transmitters to be reprogrammed. 6. Turn ignition switch OFF. All doors should lock then unlock. On Contour and Mystique models the horn will sound and the exterior lights will flash. 7. Remove short (Econoline models only). 8. Install any trim previously removed. 9. Verify transmitter operation. RKE Programming Connector Location The Two-Pin RKE Programming Connector Is Located; Taurus/Sable Wagons - behind the left side trim panel inside the cargo area. Remove the trim panel for access to the connector. Taurus/Sable Sedans - Under the left side of the package tray. Contour/Mystique - under the right side of the instrument panel, behind right side of glove compartment. Reach up behind the glove compartment for access to the connector. Probe - in the trunk behind the subwoofer on the right side of the vehicle. Remove the subwoofer (if so equipped) for access to the connector. Mark VIII, Crown Victoria, Grand Marquis and Town Car - behind the glove compartment. Open the glove compartment, compress the sides to allow it to fully open and let it hang for access to the connector. F-Series and Bronco - under the drivers side of the instrument panel above the drivers right foot area. Mustang - in the trunk behind the left side trim panel. Loosen the lining board (convertibles only) and the rear and left side trim covers to gain access to the connector. Thunderbird/Cougar - behind the left side trim panel inside the trunk. Remove the trim panel for access to the connector. Explorer - behind the left quarter utility compartment access panel. Remove the panel for access to the connector. NOTE !!! Windstar - behind and to the right of the glove compartment, compress the sides to allow it to fully open and let it hang for access to the connector. THIS MAY BE OUT DATED... Automotive Network, Inc., Copyright ©2012
