Help Please_how To Remove Steering Wheelkodieze2 10-11-2007, 01:46 PM i have a 1989 chevy caprice, i need step by step instructions on how to remove the steering wheel to put a new steering column and ignition in..i can use all the helpful info i can get please and thank you PeteA216 10-11-2007, 10:46 PM So are you trying to replace the entire steering coumn, or just the ignition? mike561 10-11-2007, 11:23 PM you will need a steering wheel puller most importantly PeteA216 10-12-2007, 12:39 PM And a locking plate remover as well to get to the ignition. Both can be bought or rented at auto parts stores. You'll need the locking plate tool to put it back together as well because what it does is push the locking plate back so you can get to the little spring clip that holds it in place. bobss396 10-12-2007, 01:45 PM I've had mine off and on so many times, I can do it while drunk and in the dark! Bob silicon212 10-12-2007, 04:10 PM ... and one hand tied behind your back, just to make it fair! I've also done it soooooo many times, an ignition lock cylinder replacement takes me 5 minutes. PeteA216 10-14-2007, 12:05 AM I've also done it soooooo many times Same here... the first time it looks intimidating, but now it's almost like second nature. Automotive Network, Inc., Copyright ©2012
