oil in my air filtervikingwrestling130 10-09-2007, 12:51 PM im getting oil in my air filter, what does this mean how can a fix it if someone could help me out on it, also where the vacuum lines meat theres oil on those to maybe theres a leak there what can i do to fix this any help i would appreciate thanks Stodden 10-09-2007, 02:36 PM I am pretty Sure it is your PCV alowing the oil to pass by dave92cherokee 10-09-2007, 08:07 PM It sounds like the PCV valve like stated above. Also check the oil dipstick and radiator to see if there's any AF in the oil or oil in the AF. If it is then it's pointing towards a blown head gasket. When was the last time you changed the oil in it, and did you put the right amount of oil back in? If you put to much oil back in then it's possible that there's to much oil pressure causing it to blow out. wwwildman 10-10-2007, 09:30 PM This is caused by oil blow-by from CCV system. There are two things to do: This is usually caused when the front CCV tube develops a crack or becomes plugged OR When the valve cover becomes filled with sludge. I would check on the skinny tube coming from the back of the valve cover to the intake manifold. Make sure there are no cracks or that it is blocked. Advanced carries the grommet, the vaccuum tube along with the vaccuum assembly that connects to the front of the valve cover. In my experience, when I have pulled the skinny tube from the intake manifold at looked at the fitting, it would be clogged. I use a pipe cleaner or small allen wrench to clean the fitting and then the problem goes away until it clogs again. Here are some links to fix: http://www.jeepxj.com/JeepXJ/oil%20blowby%20fix.htm http://jeep.off-road.com/jeep/article/articleDetail.jsp?id=257836 Automotive Network, Inc., Copyright ©2012
