visor question
-crash-
10-07-2007, 11:12 AM
Hi I have an 02 TB and I need to remove the headliner and the only thing holding me up... or should I say the headliner up is the darn Visors I don't know how to remove them anyone ever remove them ? please help thanks for your time Keith:popcorn:
emt1134
10-07-2007, 03:47 PM
Sunshade Replacement
Removal Procedure
1.Remove the windshield garnish molding.
2.Release the front assist handle from the headliner.
3.Recline the bucket seat and release the upper portion of the center pillar trim panel.
Open and rotate the sunshade parallel to the side window.
http://service.gm.com/engif/000/000/672/672367.gif
1. Insert a small tool into the bezel access hole (1).
Important: Midway through the rotation cycle, the tool will move further into the access hole.
2. Push upward on the tool while rotating the sunshade parallel to the windshield. The sunshade pivot arm bezel should appear to be recessed into the bezel.
http://service.gm.com/engif/000/000/930/930979.gif
Important: Ensure the pivot arm is recessed into the bezel before removing the sunshade from the headliner.
1. Apply outboard pressure to the sunshade while the sunshade is parallel to the windshield.
http://service.gm.com/engif/000/000/930/930983.gif
1. Pull the sunshade downward while maintaining outboard pressure to the sunshade. You will notice a separation between the headliner and the sunshade bezel.
2. In order to remove the sunshade from the headliner, carefully grab the headliner at the windshield pillar area and apply downward pressure while gently rocking the sunshade up and down.
http://service.gm.com/engif/000/000/672/672434.gif
1. Remove the inboard retainer screw.
2. Remove the inboard retainer (1) from the headliner.
3. If the vehicle is equipped with lighted sunshades, perform the following steps:
http://service.gm.com/engif/000/000/772/772180.gifA.Reach above the headliner to access the electrical connector (1).
B. Remove the electrical connectors from the headliner substrate.
C. Disconnect the sunshade electrical connector from the headliner harness.
Remove the sunshade from the vehicle.
(Information from GM service manual)
-crash-
10-07-2007, 07:13 PM
thankyou for the quick response !!! exactly what I needed :) where did you get that information ? is there a web site with that kind of info emt1134 ?
emt1134
10-07-2007, 10:20 PM
I work for a General Motors dealership, so I have access to this sort of information.
