'03 Civic EX Coolant smell, Temp rising
92RS
10-06-2007, 11:52 PM
Hey,
So the GF has a 2003 Civic EX and today after a 45minute drive, I got a whiff of 'freeze. I couldn't find a leak anywhere, either liquid or steam. Tonight, I go to the drive-thru and while waiting for food, the temp starts to come up. I shut it down and waited for the burgers. Parked and ate, drove 14miles home with no issues. Upon returning home, I sat with the car in park and at idle for about 4-5minutes and the temp came up again. I shut it down again, and then put the key to the on position, and the fan ran and temp started to return to normal (a bit below half, 3/8ths or so). I didn't notice the fan running before I shut the car down.
I have a coolant smell intermittantly, high temps at idle, coolant bottle WAY more full than it should be, but not blowing bubbles. Can't find a leak anywhere. Car will, at least for now, maintain normal temp while driving.
I'm thinking one of a few things:
T-Stat
Rad Cap
fan switch/relay
Water pump
(Gasp...)cracked head or worse
Where do I begin? Cap and Stat is my vote, but i'm not really great with cooling diagnostics or Hondas for that matter.
Any help?
Thanks,
Jay
92RS
10-07-2007, 11:00 PM
Update: Replaced the Rad. Cap after topping off the anti-freeze. Now, the fans won't kick at all........ What is the most likely culprit for this? I know they were working the day before yesterday, I heard them distinctly.
Help? It's almost Monday, and this is her only transport to and from work.
Thanks,
Jay
Copytech99
10-08-2007, 09:28 AM
Will they come on with A/C ??
Many of the relays are the same part # you could swap the cooling fan relay with one of the others. (easy no cost test, mark relays so you know which is which)
Greenblurr93
10-08-2007, 12:13 PM
if the coolant smell is comin from the exhaust and you cant smell it from in the engine bay, its most likely a headgasket. if you can smell it from the engine bay, its likely a leak, or its building up too much pressure and coming out the overflow or rad cap. I suggest replaceing the T-Stat just to be on the safe side, they're cheap and you wont harm anything by replacing it
92RS
10-08-2007, 08:45 PM
Thanks for the replies.
The smell is from the engine bay, but nothing is leaking either water or steam.
The cooling fan does not run on it's own. I am going to assume that the AC fan works based on the fact that the AC itself is functioning properly.
I'll try the relays. Sounds like it could be worth a shot anyway.
The temp hasn't come up again since the other night. I changed the cap and topped the rad.
T-stat will be next.
Thanks,
Jay
CSully
11-25-2007, 05:53 PM
coolant fan and a/c fan= same thing
Greenblurr93
11-25-2007, 10:31 PM
Hmm... if he has a half sized rad and condensor.... then no they arent the same.. he will have one for the rad and one for the ac condensor
