Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Nonspecific
Old 10-06-2007, 06:36 AM   #1
silveradoseaver
silveradoseaver Normal reputation
cupped tires
I let my 99 silverado go too long before rotating the tires and now they are worn uneven. there is a pretty good vibration in the front end. I know there is nothing I can do to "fix" the tire, but I am curious if the vibration will damage anything else over time. I am 99.9% sure it is the tires. It didnt start until i rotated them.
silveradoseaver is offline   Reply With Quote
Old 10-07-2007, 10:00 AM   #2
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Blue Bowtie Normal reputation
Re: cupped tires
If I understand your post, you have rotated the tires, and now evidently have good, square tires on the front, and it has started vibrating as a result. If that's the case, check the camber and toe-in.
Blue Bowtie is offline   Reply With Quote
Old 10-08-2007, 06:25 AM   #3
bobss396
bobss396's Avatar
bobss396 Normal reputation
Send a message via AIM to bobss396
Re: cupped tires
Cupped tires go with things like worn shocks, so check them out first. If the cupping is not that bad, the tires may be able to be "shaved" by a shop that specializes in 4X4 wheel alignments. They basically spin the tire and use a tool that evens out the tread.
Bob
bobss396 is offline   Reply With Quote
Old 10-08-2007, 03:15 PM   #4
J-Ri
J-Ri's Avatar
J-Ri Normal reputation
Re: cupped tires
It is also common to have an out-of-balance (usually a weight has fallen off, unless you're 'drifting' around corners) tire in the back that you can't really feel, but it becomes noticable when moved almost right under your feet.
EDITED to put the "t" in drifting
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
'86 3/4 ton Silverado
350 V8, 4x4, 4" lift, 1 ton axles swapped, converted to 4 wheel disc
35" BFG Mud Terrain T/As
Shortened to 109.5" wheelbase for those tight trails
http://www.boycottpepsico.com/default.aspx
You see "Fresh oil, loose gravel"; I see "Free undercoating"
J-Ri is offline   Reply With Quote
Bookmarks
Google
Web AF
