how do you remove relays from fuse block?
Ryman88
10-05-2007, 03:53 PM
In a 2000 Malibu how do you remove the relays from the fuse block under the hood?
My DRL's, fog lights, and rear lights aren't working and I want to check the relay since I can't find any bad fuses. Don't want to break anything removing the relat the wrong way.
TIA
Ryan
Speedy_1234
10-05-2007, 06:38 PM
Well, With your hands you can wiggle them until they come out if it don't work well, try a screw driver flat head and carefully on all four sides try to pry it up if that doesn't work well get some pliers and pull it up.
Ryman88
10-05-2007, 07:33 PM
OK thanks. I'll give it a try.:)
Bill
Ryman88
10-05-2007, 09:39 PM
Speedy,
Thanks for the help. All the relays and fuses are good so I guess it's into the shop. Appreciate you taking the time to offer advice.
Ryan
bcopeland
10-14-2007, 06:20 PM
Sounds like it could be a bad ground.
stratford_boy
10-14-2007, 06:48 PM
Sounds pretty in-depth, wouldn't try anything more than checking fuses/relays in the driveway.
