'97 expedition air suspension probs continue
crash69
10-05-2007, 07:36 AM
this air suspension system has drivin me nuts for years. replaced the compressor 2x. fixed some wiring issues............now the f'n thing is sagging
once again. does anybody know if there is a way to inflate the system using a compressor other than the one under the hood?
i figure i should be able to tap into the system somewhere and inflate the damn bags manually.
anybody have any suggestions?
i'll never buy another ford product again. i loved this truck for the first couple yrs but i have had nothing but issues with it lately.
wait till your spark plug flies out of the block when you least expect it. trust me - it will.
kruser
10-30-2007, 09:59 PM
Sure, you can tap the air lines.
Just follow them from each shock.
The rear air bag shocks have solenoids at the shock so you need to energize them in order to allow air to flow I think.
The front shocks are more normal and you should be able to follow the air lines back to a tee and fill at that point.
If you are going through compressors then I'd suspect you have a leak.
My 99 had several leaks and most were at the "T" or "Y" fittings in the small 1/8 inch air tubing.
I simply took apart each fitting and replaced the "O" rings in each and all has been fine since.
I also used a o ring lube product which is basically a non hardening silicone gel.
Since all this I have been riding level and the compressor does not run often.
I used a bubble leak detector on kmine called Big Blue.
It is used for finding refrigeration leaks in AC systems but works great for the air shocks on the ford!
I'd try and fix it before you give up as it is a good system when working properly!
phoophan
02-10-2010, 11:42 AM
Stop wasting your money on trying to fix the air suspension and go buy a conversion kit to get rid of it. You can pick one up for $500 and do away with the air. Try Strutmasters.
jules44
02-01-2011, 07:37 PM
saw ur post.. on the convertion kit .. do u need to replace the front too??? I was told the its all one system and that the front would fall if not replaced at the same time??? is this true ... please advise thx j
danielsatur
02-01-2011, 08:12 PM
It's like messing arround with used tires, there going togo bad!
See http://www.arnottindustries.com for replacement air bags.
Lifetime warranty
jules44
02-01-2011, 08:54 PM
this is the 3rd time in 3 yrs.. that its fallen... i need to get it fixed ..but on a budget.. which way is best .. thx much for ur in put..j 97 expedition eb
Sarge1968
05-04-2011, 08:36 PM
try the monroe kit part #90005 for 2wd and 90006 for 4wd cost at advance is 199.97 plus tax comes with coil springs and 4 shocks
