13B Turbo in N/a Chassis
Google
Web AF
Netsu
10-04-2007, 01:38 AM
Hi, I found a JDM 13B Turbo with tranny for relatively cheap and now I am looking at chassis to put it in. My question is this: Will everything match up if i drop this into an N/A FC chassis. Like the drivetrain, shifter, fuel systems, mounts. I am not familiar with the FC as I was an FB owner.
drftk1d
10-20-2007, 04:23 PM
it fits physically, and uses the same engine mounts, but you have to use the turbo transmission it came with and get a custom driveshaft that will fit the turbo trans and n/a rear because the turbo rear diff has a larger diameter input
you can also just swap over an entire turbo rear which is the best option if you ever want to build for power
Google
Web AF
