Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Corolla/Matrix/Voltz
Old 10-01-2007, 12:59 AM   #1
pmp81
pmp81 Normal reputation
89 Corolla Issue
Hey All,
I have a 1989 5 door hatchback Corolla with the 1.6L carby Engine.
I was driving on the highway when all of a sudden the car just lost power and died.. won't start again. I've already checked the timing belt, it's all in 1 piece and looks fine. It's not turning though, neither is the rotor (obviously). Just wondering what else I should look at.
The bottom cog doesn't appear to be turning either.
Regards
Paul
pmp81 is offline   Reply With Quote
Old 10-30-2007, 11:19 AM   #2
rockwood84
rockwood84 Normal reputation
Re: 89 Corolla Issue
i have seen the timing belt strip out lugs at the bottom cog which is the crankshaft cog. it will let the crankshaft turn and not move the belt which has to move the rest of the cogs. if it does this then it will get out of time and will not start . if you look at the lifters through the cap that you put oil in on the valve cover and get someone to crank it over if the lifters don't move when it is cranked over the the belt is stripped out
rockwood84 is offline   Reply With Quote
Bookmarks
Google
Web AF
