1999 Taurus Power Lock Actuator ReplacmentMJK01 09-30-2007, 12:56 AM The power locks on the two rear doors stopped working about 3 weeks apart. Power is reaching the actuators since I detect slight movement when I try to lock/unlock the doors from the driver's seat. I purchased 2 new actuators, and armed with my handy Chilton's book started to attempt a replacement. I removed the door trim, the 3 torx latch bolts and then promptly got stuck on the next set of instructions: "Remove the . . . rear door latch assembly." I can see the rear door latch assembly & actuator, but it looks very little like the diagram in Chilton's although the spartan directions seem like they should work. (For example, it describes how to detach the actuator from the latch assembly. In the book diagram, however, the actuator is fastened to the door itself with a nut and seems to be separate from the latch assembly [see page 10-11]; in my '99 Taurus the actuator is attached directly to the latch assembly with no nut.) My dilemma is that I can't figure out how to remove the door latch assembly to position it where I can actually work on it. A 1/8" steel rod is connected to it that runs the length of the inside of the door to the lock post. The door latch assembly location (with torx screws removed) makes it inaccessible to detach the rod. Another shorter rod connects the door latch assembly with the outside door handle, again inaccesible. Chilton's offers no details on dealing with these rods. Short of taking my car to my mechanic, is there a halfway simple process for removing the door latch assembly? Thanks. TaurusKing 09-30-2007, 06:43 PM Here's this out of my manual, unfortunately no pics to go with it.. Rear Removal 1. Position window glass in the up position. 2. Remove rear door trim panel (27406) and watershield. For additional information, refer to «Section 01-05». 3. Check all hardware connections to rear door latch and inside door handle, including bellcrank and pushbutton rod. Service as necessary. 4. Remove rear door pushbutton rod. CAUTION: Do not drive out the center of the bellcrank rivet, or the door sheet metal may be damaged. Drill the rivet or cut the head of the rivet to remove it. 5. Remove one rivet retaining rear door latch bellcrank (26448) to rear door as described. 6. Remove rear door latch control rod retainer (220A48) from door by twisting with a flat-blade screwdriver. 7. Disconnect electrical connector for the door ajar switch. 8. Disconnect electrical connector for the adjunct power door latch actuator (if equipped). 9. Open retainer attaching outside door handle control rod to rear door latch. ÚÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿ ³ Item ³ Part Number ³ Description ³ ÃÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´ ³ 1 ³ W525172-S ³ Rivet ³ ÃÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´ ³ 2 ³ -- ³ Rear Door Lock Rod (part of rear door ³ ³ ³ ³ latch and remote control assy.) ³ ÃÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´ ³ 3 ³ -- ³ Rear Door Latch Control Rod ³ ÃÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´ ³ 4 ³ 26412 ³ Rear Door Latch (RH) ³ ³ ³ 26413 ³ Rear Door Latch (LH) ³ ÃÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´ ³ 5 ³ N811471-S100 ³ Screw (3 Req'd) ³ ÃÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´ ³ 6 ³ -- ³ To Door Latch Actuator ³ ÃÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´ ³ 7 ³ N807736-S ³ Cable Clip ³ ÃÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´ ³ 8 ³ 220A48 ³ Retainer, Rear Door Latch Control Rod ³ ÃÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´ ³ 9 ³ -- ³ Bellcrank (part of rear door latch and ³ ³ ³ ³ remote control assy.) ³ ÃÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´ ³ 10 ³ 264A50 ³ Rear Door Latch Bellcrank Pivot ³ ÃÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´ ³ 11 ³ 391600-S417 ³ Bellcrank Rivet ³ ÃÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´ ³ A ³ -- ³ Tighten to 10-14 Nm (89-123 Lb-In) ³ ÀÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ 10. Remove three screws retaining rear door latch to rear door. 11. Remove the door lock actuator rivet. . 12. Feed latch and link rod forward in door far enough to twist and remove latch from link rod. Leave link rod in this position in vehicle. Remove door latch from vehicle. 13. Remove cable watershield and cable from door latch. 14. Remove the rear door latch. 15. To remove door ajar switch, use a flat-blade screwdriver to gently pry apart inner latch casing while twisting door ajar switch clockwise (for RH door latch) or counterclockwise (for LH door latch) until switch releases. Remove door ajar switch. 16. To remove adjunct door latch actuator, release tab on actuator and slide actuator off door latch. 17. Transfer components to new door latch as required. Installation 1. With the following exceptions, follow removal procedure in reverse order. 2. Replace rear door latch bellcrank pivot (264A50). 3. Use Heavy-Duty Riveter 501-D011 (D80L-23200-A) or equivalent to install rivet 391600-S417 that attaches bellcrank assembly to rear door. 4. Tighten rear door latch retaining screws to 10-14 Nm (89-123 lb-in). MJK01 10-01-2007, 12:40 AM Thank you so much. These directions make sense. I appreciate the time you took to look this up. Thanks again. Automotive Network, Inc., Copyright ©2012
