1993 - 3.1 - Rad. fans not working
Hi!
First, check engine light went on but since there was no other issues I was driving it maybe week or so. One day, when driving home I started sense smell of cooling fluid inside the car, so I stopped it and found gasket blowed out under pipe next to the water pump. Because leek was not big and I was close to home I decided to drive home. That time I saw left side fan was working. Next day I replaced gasket and check code - it was #15, so I started to look for other cooling related problem and found cracked plastic housing of temp. sensor located on side of the thermostat so, I replaced it. I also found so rad. fans don't work at all. also with turned on A/C, but when I was checking CES light code, both fans were on. Why fans don't work?!?! Cooling fluid is circulating because heating system is blowing hot air inside the car and also return hose from thermostat to radiator is becoming hot just minutes after starting engine.
Can someone help me find problem?
Andrew
