MAZDA 6s SPECSbrock cummings 11-26-2002, 08:37 AM Mazda 6 : engine 2.3L DOHC 16-valve 4-cylinder 160@6000rpm-horsepower 155@4000rpm-torque 137.9-cubic inches 9.7:1-compression ratio 3.0L DOHC 24-valve 6-cylinder 220@6300rpm-horsepower 192@5000rpm-torque 181.1-cubic inches 10.0:1-compression ratio fuel-regular unleaded type- FWD transmissions-M/T-5-speed manual A/T-4-speed EC dual-mode AT w/overdrive 1st-2.816 2nd-1.497 3rd-1.000 4th-0.725 5th------- reverse-2.648 final drive-4.105 A/T-5-speed EC dual-mode AT w/overdrive 1st-3.801 2nd-2.131 3rd-1.364 4th-0.935 5th-0.685 reverse-2.970 final drive-3.712 front suspension independent, high-mount double wishbone,coil springs and stabilizer bar rear suspension independant, E-type multi-link, coil springs and stabilizer bar turning circle, curb-to-curb (feet)-38.7 front brakes-ventilated discs(11.1x1.0 inches) rear brakes-solid discs(11.0x0.4 inches) wheels 5.0JJ x 16(steel) 7.0JJ x 16(alloy) 7.0JJ x 17(alloy) tires P205/60R16 91 H-rated all-season steel-belted radials optional P215/50R17 93 V-rated all season curb weight M/T 4-cylinder 6-cylinder 3042lbs 3243lbs A/T 3091lbs 3311lbs brock cummings 11-26-2002, 08:46 AM I didn't see any thing solid on the new 626 so I posted the info up top. my girl has a 97 626lx and I am going to let her trade it for a V6 mazda6 with the sports package , I have see them for about 25,000. I am going to make a post on the compare a car link for the mazda6,toyota camary, and nessan altima3.5 a lot of prevews compare these cars. Automotive Network, Inc., Copyright ©2012
