engine code P0030
solidg
09-25-2007, 12:56 AM
bad oxygen sensor right
which one though?
brody1
06-29-2008, 02:30 PM
Trouble codes for all Intrepids 1993-2004
GA_googleFillSlot("Forums_ROS_300x250_noad"); Hello everyone,
I've created this thread to help out those who have a Dodge Intrepid or any Daimler-Chrysler vehicle that was built from 1996-present. If you have a check engine light and need to know what the code is, visit this website to give you the answer(s) to your code issues. The website is:
http://autorepair.about.com/cs/troub...l_obd_main.htm (http://autorepair.about.com/cs/troubleshooting/l/bl_obd_main.htm).
If you have a 1993-1995 Intrepid and you have a check engine light, you can find out what the codes are by following this process:
1. Turn the ignition key on/off 3xs ending in the ON position
2. Watch the "CHECK ENGINE" light and see if it flashes.
3. If it flashes twice then pauses and flashes again another 4xs, that's a code 24, for example. You have put the computer in diagnostic mode and it will now display any codes that have been stored in memory. Here is a list of all codes that can be displayed and what they mean:
12- Problem with stand-by memory circuit. Direct battery input to controller disconnected within the last 50 ignition key-ons.
13- Indicates a problem with the MAP sensor pneumatic system.
14- MAP sensor voltage too low or too high.
15- A problem with the vehicle speed sensor signal. No speed sensor signal detected during driving conditions.
16- Loss of battery voltage
17- Engine coolant temperature indicating engine temperature cold too long.
21- Oxygen sensor voltage not fluctuating.
22- Coolant sensor voltage too high or too low.
23- Throttle body temp sensor below acceptable parameters.
24- Throttle position sensor voltage too high or too low.
25- Automatic Idle Speed motor detects a shorted condition in one or more circuits
26- Peak Injector current has not been reached.
27- One of the injector control circuit output drivers does not respond properly to the control signal.
31- Problem with the canister purge solenoid circuit
32- An open or shorted condition detected in the EGR transducer circuit.
33- Air conditioning clutch relay circuit open or shorted.
34- Open or shorted condition found in the speed control vacuum or vent solenoid circuit.
35- Radiator fan relay circuit open or shorted.
36- Problem with the air switching solenoid circuit.
37- Open or shorted condition detected in the torque converter unlock solenoid circuit.
41- Problem with charging system. Voltage below 11.75.
42- ASD (Automatic ShutDown) relay control open or shorted.
43- Engine misfire in one or more cylinders.
44- Ambient/Battery Temperature too high or too low.
45- Transmission temp sensor not indicating warm condition.
46- Charging system voltage too high.
47- Charging system voltage too low.
51- Oxygen sensor signal indicates a lean condition.
52- Oxygen sensor signal indicates a rich condition.
53- Internal PCM failure.
54- No cam signal to PCM.
55- End of code message.
62- Unsuccessful attempt to update EMR mileage in the controller EEPROM.
63- PCM failure. EEPROM write denied.
These are all the codes for most 1993-1995 and a few 96 and 97 Intrepids. If you need any others if I missed them, please let me know.
