Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 09-24-2007, 02:34 PM   #1
hink123321
hink123321 Normal reputation
ATF fluid level check-This doesn't make sense!
01 S-10-4.3L-Auto trans
Was checking my ATF level yesterday and everything was normal. I checked it when the engine temp was hot. I wanted to check it also when the engine was cold. Much to my surprise when I checked it the level was about 1 inch "above" the full mark. I came out this morning and checked it again(cold) and it showed the same reading. I took the truck out and checked it with the temp hot and the level was back to normal. Am I missing something here? Every vehicle before when I checked it when cold the ATF fluid would read low and the hotter it got it would expand. It's seems to be the opposite with this transmission. Any ideas on what's happening?
hink123321 is offline   Reply With Quote
Old 10-10-2007, 09:57 AM   #2
maurerush2112
maurerush2112 Normal reputation
Re: ATF fluid level check-This doesn't make sense!
the reason its higher when cold is that some "drain back" occurs when shut off. yes the fluid expands when hot, but when you shut down for couple hours/overnite,etc. the torque converter, and main body areas drain back down because pump isn't pushing it up and around
maurerush2112 is offline   Reply With Quote
Old 10-16-2007, 10:25 PM   #3
troy1
AF -Advisor
troy1 Normal reputation
Yes you need the engine running to check ATF level
troy1 is offline   Reply With Quote
Bookmarks
Google
Web AF
