92 Pathfinder sputters a lot when starting to move.
Firewind
09-24-2007, 11:02 AM
I have a 92 Nissan Pathfinder that is sputtering a lot, almost like it's going to stall out when I am going up hill or even when I just start to get going in 1st gear. Even when I floor it, if the engine is giving too much of a load it seems to wanna almost die out on me. There's a little smoke that comes out too when it acts up.
It seems better once the truck is warmed up.
I replaced sparkplugs to see if that helped and it didn't really help at all. Also the wires tested out fine, and distrubuter cap seems fine as well. I have cleaned out the throttle body too.
There's also a slight knot that you can barely hear at 3000+ rpms.
Any ideas? I'm assuming one of my pistons (Or a few of my pistons) rings are bad.
88pathoffroad
09-25-2007, 10:09 PM
Try cleaning your mass airflow sensor, check the air filter, run the ECU error codes and see if anything is stored, change the fuel filter, the list goes on.
