97 grand am key won't turn
deanr221
09-23-2007, 10:43 PM
my key won't turn in ignition.....tried different keys ...tried lubricating cylinder won't budge....how do you remove lock cylinder and can you replace it without passlock problems
xeroinfinity
09-23-2007, 11:12 PM
Most likly forcing it will be the only it'll move ,
did you make sure it's in park??
deanr221
09-23-2007, 11:36 PM
yes ,it's in park....is there any solenoids or cables from shifter that could lock it up?
xeroinfinity
09-24-2007, 11:52 AM
Yes thier is a brake/trans shift interlock solenoid(BTSI), is located in the console under the shifter.
And a park nuetral safty switch which is under the hood on top of the trans, has the shift cable connected to it.
Might check those before breakin the ignition or key.
Hope that helps.
