Power Window Fix - $0 costpittstategorilla97 09-23-2007, 02:33 PM I can't take credit for this write up, I found it on the Chrysler.com website but it did work for me and it cost $0 to try. I used the procedure to fix the drivers side window on my 02 T&C EX. "After removing the door panel and lifting the inner liner you will see the window motor and cables bolted to the inside of the door by 3 torx screws (torx 30). Loosen the torx screws enough to remove the two phillips screws that attach the metal housing that contains the armature and magnets from the rest of the device. There are two nuts that slide in small slots. Be sure to watch if they fall out. They can be easily reinserted. The metal housing with the armature attached to the screw portion of the worm drive will now be easy to remove. You will now see two braided copper hoops sticking out from the point where the metal housing came off. These are the problem. They can get caught in the armature. Push them back away from the brushes and where the armature spins. Now take the armature and screw drive out from the magnets and housing. Put the screw portion of the motor back into the worm gear and turn a few times so that it screws in. The metal housing with the magnets will now slide right back on. Tighten the two phillips screws. Tighten the torx screws (you may need to reach behind to the rubber portion they screw into to keep it from turning). Put the panel back on - don't forget to reconnect the electrical connections and door handle." Automotive Network, Inc., Copyright ©2012
