2007 instrument panelgenegr 09-22-2007, 08:45 PM My instrument panel went completely dead today after pulling a rental trailer. Also the blinkers and stop lights. I can't seem to find the bad fuse. Would this be the self resetting fuses refered to in the manual, serviceable only by a dealer? thanks Stretch58 09-23-2007, 01:40 PM Did this trailer just have a plug you hooked up to or did you or someone have to experiment around hooking wires up to make the trailer lights work? genegr 09-24-2007, 07:06 PM Just plugged it into the flat plug, I have emailed chrysler and haven't got a response yet. All the trailer lights worked fine when I left the rental place. I did drive about 5 miles on a rough dirt road. thanks Stretch58 09-24-2007, 10:10 PM I assume it is still under warranty. If so I would let the dealer sort it out. If not under warranty, I would start by turning the ignition and everything else off, then disconnect the battery neg. terminal for a few minutes. Then hook it back up. See if there is improvement. Just curious, was everything off when you disconnected the trailer like ignition, lights? genegr 09-25-2007, 07:34 PM It went dead before I disconnected it. I noticed it when I was driving down the dirt road. Automotive Network, Inc., Copyright ©2012
