whinning noisejomy1127 09-21-2007, 11:23 AM hi to everyone, i just bought a 1998 buick regal gs with 104000 miles on it (private seller)since i bought it when i turn the steering wheel there is a whinning/ buzzing sound that comes from under the hood also when im in a dead stop and try to turn my steering wheel is hard to turn left or right but when im driving its not that bad there is fluid in the resevoir. my question is, is it the pump or the steering rack thanx in advance , also there is no leaks that i could see. taillight 09-21-2007, 12:12 PM Sounds like the pump is starting to go bad. Check fluid color. richtazz 09-21-2007, 01:01 PM I agree with tailight. It sounds like either low power steering fluid or a bad power steering pump. The pump is in a bad spot on the 3800 engine, in the back below the belt tensioner assembly, so it's kinda hard to reach to check the fluid level. jomy1127 09-21-2007, 03:00 PM checked the fluid it did need some but it still is the same also the color is like brownish color is that good or bad. thanx taillight 09-21-2007, 04:24 PM Brown is the right color. Maybe it is just the pump. jomy1127 10-12-2007, 09:24 AM ok got it it turned out to be tha rack and pinion :banghead: but got it done thanx Automotive Network, Inc., Copyright ©2012
