Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 09-19-2007, 12:32 PM   #1
wilhite38
wilhite38 Normal reputation
Trouble Starting
I have a 97 Chevy Z71 1/2 ton extended cab 4x4 approximately 162K on it. Anyway, about a year ago I noticed that I was leaking transmission fluid. What happened was that my pan got a little loose and slowly leaked out fluid. Anyway, fixed that problem. However around the same time I started to have trouble starting the truck. I would turn the key and it would sort of grind a little bit. Then I would let go and turn again and it would start. However, it could be totally unrelated.
Then came winter and I had no problems at all starting the truck.
Summer came again and I have had the same problem. Sometimes it starts up sometime, it takes a few turn. What it sounds like is there is something spinning around. After a couple of tries it ends up starting. I have no idea what this is. It has never not started, but I don't want to get caught where it actually finally falters.
Anyway, any suggestions would be greatly appreciated!
Thanks
Rob
wilhite38 is offline   Reply With Quote
Old 09-19-2007, 12:36 PM   #2
taillight
taillight Normal reputation
Re: Trouble Starting
From your discription it sounds like your starter drive is going bad.
taillight is offline   Reply With Quote
Old 09-19-2007, 06:54 PM   #3
acewelderman
acewelderman's Avatar
acewelderman Normal reputation
Maybe a bad starter !Does it start hard on hot restarts?Maybe heat soak.A rebuild will cost less than a tow for sure!Good luck!
JUST WELD IT !!
acewelderman is offline   Reply With Quote
Old 09-19-2007, 10:53 PM   #4
wilhite38
Today I left the car sitting for a few hours. I came outside and it took 3 times to start it up. Once it started up, if I am turn it off and then turn it right back on it works fine. Still not sure what it is. I did check and there were no codes that came back for it.
Old 09-20-2007, 12:21 AM   #5
Browning151
Browning151's Avatar
Browning151 Normal reputation
From your description it sounds like the starter isnt engaging properly, I had a 92 C1500 w/the 4.3 V6 that did the same thing. It was from the freeze plug right above it leaking into it. I would pull the starter and have it checked.
New toy..99 Z71 Ext. Cab OBS, Indigo Blue w/Gray Leather....
Browning151 is offline   Reply With Quote
Bookmarks
Google
Web AF
