'91 Pathy intermittant blower motorFred64 09-18-2007, 11:41 PM Within the last few months, the blower motor will (sometimes) not come on after starting the engine. Usually after about 15-20 minutes the blower motor will suddenly come on and I can adjust the speed just like normal. All vent controls work like normal. Checked all fuses - they pass tests. Blower works fine (when it comes on). DIY repair? Short circuit? faulty relay? Please advise. Thank you. FixUrNissan 09-23-2007, 10:07 PM do you have auto Air? 88pathoffroad 09-25-2007, 10:08 PM Not on a 91, no. Could simply be a bad switch. Loose wiring at the blower? Fred64 10-01-2007, 12:51 AM Auto air.... we bought it with a temp guage that helps regulate air temp and it's a rare feature. It's a nice feature and it works alot like the thermostat in your house. I removed the glove box and removed a metal cover plate to look at the blower motor housing, but was unsure what to do next... so I left it exposed in case I get more help. Symptoms are persisting. If it's a bad switch or loose wiring, I think I could tackle that one with some direction... Thanks for any help you have. Automotive Network, Inc., Copyright ©2012
