96 trooper hesitates and chokes up while accelerating, aweful burning smellnuclear_assault 09-18-2007, 11:29 PM When I drove my Trooper the other day it started making an aweful burning plastic smell. When I turned it off I heard a loud buzzing noise coming from the center console. When I started it up again it hesitated every time I tried accelerating. When I got on the highway I had trouble getting up to and over 60 at times, and other times it would get up to 80 no problem, but then it would slow back down again and start choking up. The burning smell came back when I was on the highway too. I got home and shut it off, and a few hours later when I started it again, there was a very odd noise coming from my engine. It's a very hard noise to describe. It also still chokes up and jerks around. I don't know what the problem could be whatsoever. trooperbc 09-19-2007, 02:39 AM When I drove my Trooper the other day it started making an aweful burning plastic smell. When I turned it off I heard a loud buzzing noise coming from the center console. When I started it up again it hesitated every time I tried accelerating. When I got on the highway I had trouble getting up to and over 60 at times, and other times it would get up to 80 no problem, but then it would slow back down again and start choking up. The burning smell came back when I was on the highway too. I got home and shut it off, and a few hours later when I started it again, there was a very odd noise coming from my engine. It's a very hard noise to describe. It also still chokes up and jerks around. I don't know what the problem could be whatsoever. sounds like you got a short and fried some wires. and then you continued to drive it without finding the problem and fried the computer. that's the worse case scenario i suppose. maybe you got lucky and it's not all that bad. if you can't describe the noise(s), there's not much to go on. you can just start doing some investigating around the wiring looms, looking for obvious damage(s). //bc nuclear_assault 09-19-2007, 12:52 PM well the noise is coming from the timing belt........so it's probably fucked......and im pretty sure thats where the smell was coming from too trooperbc 09-20-2007, 12:17 AM well the noise is coming from the timing belt........so it's probably ......and im pretty sure thats where the smell was coming from too ah, so that would make sense. many times (especially if the water pump bearing freezes up) the timing belt will get akilter on the pulleys and start rubbing on the timing belt covers and actually slice them in two. so you know you will want to replace the tbelt, timing belt tensioner, and water pump. and inspect the pulley bearings and replace if necessary. but what about the smell from the console? //bc nuclear_assault 09-20-2007, 01:38 AM there was only a buzzing noise coming from the console that sounded like something was shorting out Automotive Network, Inc., Copyright ©2012
