Removing the orange from my headlightspnut420 11-24-2002, 05:50 PM Does anyone know at what temperature to set the oven at, and also how lond do you put them in for..... It is tuff getting rid of the glue... 02SilverSiHB 11-26-2002, 08:36 PM put them in there for 15 minutes at 250 degress F. It gets the sealant real hot and easy to pull apart. Also, after you're finished, put the headlight together and put it back in the oven at the same temp and time. Then push it back together again, real good and then use some sealant if you feel you need to. fawkishjon 01-24-2003, 06:40 AM STICK IT IN THE OVEN???? LOL DUDE USE A BLOW DRYER:rolleyes: kicker1_solo 01-24-2003, 07:21 AM Originally posted by fawkishjon STICK IT IN THE OVEN???? yes! KrNxRaCer00 01-24-2003, 01:06 PM blow dryer. use gloves, get ur moms hair dryer an go at it. this way u can avoid any unwanted melting (don't kno if 250 would hurt it, but i wouldn't take the chance), when u can jus use a hair dryer all the way around. emerge 01-27-2003, 12:58 AM when i did mine, i used a hairdryer. BUT, that took forreeevver. and as i went around the headlight, the silicon would keep resealing on the parts i had already pulled apart. alot of people have used an oven to do it and they came out fine. whichever you do, im sure will work. post pics! Dinzdale40 01-27-2003, 07:38 PM The oven works great, it gets the plastic hot and melts the seal. 250 isn't enough to melt the plastic. It should be fine. Gusto222 02-04-2003, 01:22 AM sohc_vtec 2NR 02-05-2003, 09:45 PM using the oven should be fine....unless ur patient enough to use a blowdryer.... moondawgy 02-10-2003, 03:51 PM most ppl just 'bake' their lights to remove the orange it's much faster and simpler than hairdryer Civic98 02-11-2003, 01:24 PM i cleared out mines last Sunday and i used a hairdryer it doesn't take too long ...... BrokenLimits 02-11-2003, 03:56 PM Automotive Network, Inc., Copyright ©2012
