I have a 2001 Subaru Outback. Both my front and back windshied wiper fluid dispenserw don't work. Windshield wipers themselves work fine. No burnt fuses. Plenty of fluid in tank. Any ideas?
Thank you.
Reason: To add something
take the time to take the switch apart and look for broke or loose wires. Also do the same right at the washer pump. I had the same problem and found it to be a disconected wire connection on the pump
Also check all of the hoses and make sure that nothing got plugged in them. On one of the connectors there is a spring powered ball that will regulate the flow, and I found that taking that ball out I was able to get washer fluid through.
