tyre suggestion
tradco
09-17-2007, 02:12 AM
can someone suggest if 19" tyres or 20" tyres would be suitable on the 7 series.
if possible can u give some comparision of using 19" or 20"
thanks
PAHA740IL
10-16-2007, 12:27 AM
20" will look good but after a while ur bushings will wear out and when u will break, your steering wheel will vibrate strongly....i would go for 19" or some nice 18"
lincolnmaster80
10-16-2007, 09:21 PM
Yes. As there is less sidewall flex on bigger rimmed tires, vibrations and bumps are a lot harder, you lose the "soft" ride with the stock 15" or 16". Before you buy any sized rim, research what bushings and parts wear most commonly, and look up on online part sources for the replacement cost of those parts and see if you can afford to replace those parts all at once about a year or two down the road (depending how much you put on your car in a year)
http://www.autuhausaz.com
http://www.autopartsonlinecanada.com
