still stuck in second gear
joeg92083
09-15-2007, 05:19 PM
ok i haave posted about this before and still having same problem...i have a 95 aurora that i replaced ecm, shift selonoids and filter, tranny flush and the car still wont shift out of second??? any suggestions???
maxwedge
09-15-2007, 08:10 PM
Do you have power to the shift solenoid connection to the trans? Has this been scanned with a trans function scanner that can command the solenoids and confirm their operation? Is this second gear start and no shift or 1-2 only?
joeg92083
09-16-2007, 10:11 AM
i dont know what kind of scanner my car got scanned with but i had the work done at an established transmission shop in my area so i dont know if there is actually power going to the solenoids........its stuck only in 2nd gear...wont shift at all
xeroinfinity
09-16-2007, 01:55 PM
Trany flush... :uhoh: :nono:
I'd say tha'ts where the troubles came from.
You probly hav some passages pluged not letting it shift,
flushing is good about that.
Good Luck!
joeg92083
09-16-2007, 02:36 PM
actually im sorry...let me reword that....the mechanic said that when he changed the solenoids that most of the tranny fluid came out so he had to refill like 75% of the fluid and he replaced the filters with the solenoids so he said it basically got a flush cause it has mostly new fluid and new filters
lynzoid
09-17-2007, 01:55 PM
most likely problem is that he didn't update the tranny with new pcs filter and bracket....
senrab
09-22-2007, 07:06 PM
This might not be your problem .... but ... I had the same issue but it only did it occasonally. I replaced the computer for other reasons and haven't had a problem in 15k.
joeg92083
09-23-2007, 10:37 AM
he told me that he did update the filter and bracket...and i also already changed the computer and its still doin the same thing
