99 TOYOTA TACOMA code P0302 & PO300mingo 09-13-2007, 11:54 PM Please help..... i have a 99 toyota tacoma 3.4 engine.... check engine light with code PO302 "cylinder 2 misfire detected.....cylinder 5 misfire detected.... PO300 random/multiple cylinder misfire detected.......please if someone with same CODES what should i do to get light OFF...... THANK YOU VERY MUCH FOR HELPING ME OUT..... TcmaBoy 09-14-2007, 12:12 AM The best way to get rid of a check engine light is to fix the truck. Sounds like you have a misfire. Check your plugs, coil packs, timming, look for vac leaks, etc. A repair manual can be found here: http://www.ncttora.com/fsm/index.html Automotive Network, Inc., Copyright ©2012
